Oil Archive (no new posts) An archive of oil related questions and comments.
50w???
Old 04-05-2014, 08:47 AM
Ckpoorboy's Avatar
Ckpoorboy
Ckpoorboy is offline
Stage III
Default 50w???
Has anyone heard of running the mobil1 racing 50w oil in the engine and primary's? My uncle has been riding for 40 yrs and this is what he does. Sure it's fine, I was just wondering if anyone else did this?
Old 04-05-2014, 11:23 AM
big cahuna's Avatar
big cahuna
big cahuna is offline
Lots of people run 20/50 wt oil which is the same weight when hot. I've found using 15/40 wt oil in the primary causes less drag on the clutch plates when cold, so you don't get the bang goin into first ,and in general helps keep the shifting smooth as butter.,,
Old 04-05-2014, 12:02 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Only real problem is the extra wear during start-up. Whether that matters in the long run is your choice.
Old 04-05-2014, 03:05 PM
Ckpoorboy's Avatar
Ckpoorboy
Stage III
Thank you both
Old 04-05-2014, 03:16 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I looked and couldn't find 50wt Mobli 1 racing oil. But synthetic oils are multi vis oils naturally. I wouldn't worry about cold flow. It would probably spec out to a 20/50 anyways. Also HD Formula Plus is a straight 40wt mineral oil
Old 04-05-2014, 04:59 PM
518Train's Avatar
518Train
518Train is offline
Red line racing 50wt meets multigrade specs for SAE 15w50, so it says on the bottle.
Old 04-05-2014, 10:33 PM
pococj's Avatar
pococj
pococj is offline
Just got off the Mobil 1 website. There is no listing for Mobil 1 50, but their Mobil 1 Racing oil is available in 0w-50 and 0W-30. The oil has high levels of zinc. That makes it unsuitable for use with catalytic converter equipped machines. That is the only engine-related caveat stated on their site: "Mobil 1 Racing oils are not recommended for everyday general street use where vehicles use catalytic exhaust converters." Also: "Mobil 1 Racing oils are formulated with anti-wear (Zinc/Phosphorus) chemistries at twice the level of automotive street oils to provide enhanced protection of highly loaded valve train systems found in some race engines. Based on the high level of anti-wear chemistries, Mobil 1 Racing oils are not recommended for street use." Additionally, I would be leery of using them in the primary because of this: "These oils are not recommended for wet clutch applications due to their high level of molybdenum."
I hit the BITOG site to try for some specs. Didn't see the 0w-50, but the 0w-30 is loaded with additives so 0w-50 should work very well in a motorcycle. Except that it costs $15+ a quart!
Retrop
09-03-2013 09:50 AM
Falcon195
07-17-2012 07:10 AM
aoehero
06-16-2011 09:44 PM
car5car
12-25-2009 02:35 AM
twiceretired
01-20-2008 10:47 PM
Quick Reply: 50w???
