Oil temp install '07 Ultra
Anyone done one on an '07 Ultra. Installing P/N 70900283. don't have the kit yet nor the parts, maintenance, nor wiring schematics manuals, maybe once I get all that it'll be more clear as to what connections go where. I've gotten the fairing off, I see no connector (identified as 107) where it should be according to many previous posts, near steering head by the "P" clamp. I have located the temp sensor itself, also the air temp gauge has two plugs, a 3 pin and a 2 pin. 2 pin looks like lighting and the 3 pin I assume a feed from sensor to gauge. Can anyone tell me when the oil temp plugs in? An aside, can't believe how much easier the fairing comes off than on my old '93. Wow that used to be a major undertaking, you did anything you could to avoid it. As I remember, pulling the head lamp, and working thru the opening to get at the 4 mounting bolts, PITA! And the chrome strip under the windshield with the funky attachments also much fiddling to get installed. Photo is air sensor. Just trying to get a leg up on this, any help much appreciated!
nukie2000
2014-2023 Touring Models
06-10-2015 10:05 AM
