65 pan elec. first year elec. start problem
just bought my 2nd `65 electric start, starter worked for 3 days,
now starter spins fine but will only engage 1 out of 10 times and when it does it is only long enough to push 1 piston over tdc.
I pulled the outer primary checked the bendix, ring gear, engagement fork, spring and plunger, everything is within spec,
I then replaced the starter solenoid twice using v twin high performance solenoids and then h-ds
all results were the same,,,,,, any thoughts,
Not sure how you would check a bendix...but if the starter is spinning and the motor is not, it is usually the bendix. You can engage it with the outer primary off to help diagnose the problem.
Received 3,222 Likes
Replace the starter clutch(bendix.)
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I checked the bendix visually, no wear spots on engagement teeth, then lifted shaft just enough to clear clutch hub, and hit starter button just long enough to engage teeth to ring gear without spinning clutch hub,,, bendix engaged and disengaged properly,
I did this a dozen times.
I guess that doesn't mean it`s ok,, I assumed it was ok.
