Rear Brake light switch mount?
Can anyone provide a diagram, or describe to me where/how the stock rear brake light switch mounts on my 1950 Panhead with MECHANICAL brakes? I can't find any pics of any 50 Pan's with enough detail to show me how/where it mounts. I got the part figured out for the attachment to the rod coming off of the brake pedal, but can't figure out where to put the actual switch.
I have upgraded to a RevTech oil pump and the body of that pump is quite a bit thicker than the stock unit and if the switch mounts where I think it's supposed to mount then it isn't going to work with the RevTech pump because there just isn't enough clearance between the pump and what I think is the mounting hole on the brake crossover tube.
ANY drawing, or description would be helpful.
Thanks,
Jeff
Thanks,
Jeff
Panhead brake light switch mounting
Nope... didn't die. Still wondering if anyone has a diagram of how the stock switch mounted. If ya got one, or a picture please let me know at rancherojef@yahoo.com.
Thanks, Jeff
Thanks, Jeff
Received 3,222 Likes
Could you send me that picture also? heathhamlin@hotmail.com Thank you
Dave
Pan mechanical switch
