Linkert M-74 B Question
Old 03-04-2011, 09:16 PM
BurgundyUltra06's Avatar
BurgundyUltra06
BurgundyUltra06 is offline
Question Linkert M-74 B Question
I was having some carb issues on my new-to-me 58 Duo Glide. I pulled the carb to see what was going on. I found some things that were missing or needed cleaning, but I found a hole (that had nothing in it initially) that I didn't see in the manual that is puzzling me.
Please see the first picture -- the nicely machined hole (no threads) is above the float bowl; if the carb was mounted, it would be toward the rear cylinder. I sprayed some carb cleaner in it to see if it went anywhere and got spray into the venturi and down into where the bowl would have been.
The second picture shows a rebuilt carb of the same model. It appears to me that there is a plug in that hole. Can anyone confirm or deny the plug? If it should be plugged, any idea what material or part number?
Thank you,
Attached Thumbnails Linkert M-74 B Question-carb.jpg   Linkert M-74 B Question-rebuilt-carb.jpg
Old 03-04-2011, 11:23 PM
FLat Head's Avatar
FLat Head
FLat Head is offline
I've got an M 51 on my 38. It has the exact same hole. What we have here is your float bowl vent. One question, when you sprayed into the hole, did you have any gas in the bowl? That hole goe's in about 3/8", then angles down at a 30-35 degree angle. Nothing to concern yourself about. And I wouldnt plug it.
Old 03-05-2011, 01:38 AM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
mine is open on my 64. and its a bowl vent
Old 03-05-2011, 02:18 PM
BurgundyUltra06
Gents,
Thanks for the insight. Having a vent that goes into the perimeter groove of the venturi seemed a bit counter-intuitive to me (kinda like a vacuum leak), so I appreciate your help.
Flat Head -- I already had the bowl off and everything else removed when I sprayed carb spray in it. FWIW, I was able to slide out the venturi tube and was then able to see how that vent was ported.
Thanks again,
kjp8531
Carburetor Related
05-12-2016 12:19 AM
toxicstang99
02-04-2012 04:00 PM
atomicbeing
04-14-2008 08:34 PM
Rolson1
Classic
09-09-2007 10:03 AM
anubisss
05-31-2007 10:24 PM
Quick Reply: Linkert M-74 B Question
