frame id
Old 08-10-2012, 11:59 PM
stretch81's Avatar
stretch81
stretch81 is offline
Stage IV
Default frame id
hey guys , can anyone tell me how to tell the differance between the knuckle head straight leg frame and the panhead straight leg frame. And do i have to remove the heads to install a 57 panhead in the original 57 frame?
Old 08-11-2012, 05:57 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Default Frames
Knucks were straight leg (off the neck down) Pans were wishbone (off the neck down) If you want to see a pan frame give me an E-Mail
Old 08-11-2012, 06:02 PM
sqdealgeorge
Default Frames
Also forgot to say Knuck frames were brazed Pan frames were welded Much better ! I was lucky I have a Knuck in a pan frame Thank God !
Old 08-11-2012, 07:09 PM
stretch81's Avatar
stretch81
Stage IV
didnt they go back to straight leg from approx 52-3 57
Old 08-12-2012, 07:53 AM
sqdealgeorge
Default Straightleg pan frames
As for the rigid frames I think late 1955 thru 1957 were straight down tubes after pans went to swingarms 58 thru 65 those frames were also straight down tubes
Old 08-13-2012, 06:35 PM
stretch81's Avatar
stretch81
Stage IV
thanks guys been a good help, any info on the heads and 57 frame do i need to remove the heads to get the engine in?
Old 08-13-2012, 07:48 PM
sqdealgeorge
Default head removal
No the complete engine should go right in
Old 08-15-2012, 05:12 PM
stretch81's Avatar
stretch81
Stage IV
sweet i'll go ahead now thanks mate!
Old 12-13-2014, 07:16 PM
33rodster's Avatar
33rodster
33rodster is offline
Stage II
Thumbs up knucklehead frame
The knucklehead frame is different than a panhead frame. The front motor mount is higher. If you were to put a knucklehead eng in a panhead frame, you would need a spacer plate at the front motor mount. A panhead eng does not fit in to a knucklehead frame because of the lower back bone/seat post height.(knucklehead heads shorter in height)and because of the front mounts. As other have mentioned at a glance 1955-57 the panhead has straight leg down tubes like the 1947 and earlier knucklehead frames. 1948 to 1954 panhead frames were wishbone leg down tubes. (all had side car loops) 1958 to 1965 swing arm panhead frames and 1966 1969 generator shovelhead swing arm frame??) (all were stright leg down tubes without side car loops)
streetglide99
Shovelhead
61
12-08-2014 06:40 PM
alfajuj
Custom Models
11-27-2012 10:50 PM
citytrucker26
08-20-2010 11:58 PM
ironbutt4sure
08-09-2008 12:35 PM
68beep
Panhead
12-11-2007 12:05 PM
Quick Reply: frame id
