Whats it worth? 51 pan head
I am new to this site as you can see. here is where I need a lil' advise from the pros (thats you!).
what do you think this bike is worth?
http://cgi.ebay.com/ebaymotors/ws/eB...;rd=1&rd=1
RE: Whats it worth? 51 pan head
It looks nice enough. Think I'd message the seller and see if it was shop built. If so, it would be worth up to about $16K. If he built it, there are a few things that I find scary. 74 inch stroker? What, he stroked an EL engine to 74 inches instead of just swapping to FL barrels? Ridge frame? Does he know what he has?
Received 3,210 Likes
A chopper is worth what the market will bear....
Got a 50EL that is chopped. 2 years ago I decide to take out the stoker plates when I had the rebuild. S&S makes pistons with the piston pin hole off-set so that you can you 61 barrels. Bottom line is that pistons are a whole lot cheaper than barrels, even if you consider using Tawain Ted, which was not an option for me.
The pics look nice, tho a little too modern for me, bust still a nice lookin scoot.
vipersniper
03-28-2016 01:57 AM
