64 duo hot start
64 duo hot start
I've posted a while ago about my 64. STD pan, s&s e carb, Mallory comp distributor. I've got the technique down for a cold start. 2 pumps on throttle, 2 prime kicks, switch on, choke on, starts on 1st kick. But I cannot for the life of me start the bike hot. Its left me stranded. Tried every combo I can think of. Full throttle, no throttle, advance timing, retard timing...even if I manage to get the bike to turn over and run, it quits less than a minute later. If you try and ride it in that minute, it'll quit when you stop at a light. Ideas?
drive it around get it 1/2 hour hot than take it back home and shut it off like at a gas station and kick it 5 minutes later and when it does not start have a pitcher of water handy / pore it on the electronic dist ( too cool it off cool to the touch ) engine hot and than kick it again - cooling off the trigger that might be overheating and causing a very weak spark - will do exactly what you are explaining at a hot re start --
coil swap is another idea if you have not checked the OHMs resistance in the coil you need to as the incorrect resistance will also do what you are having issues with Hot no start - no i do not have the OHMs restance for that dist handy do you have the original directions if not give them a call -- jz
slickmyster2004
07-05-2009 06:49 PM
