Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Removng corrosion from grey painted casings...
Old 03-12-2017, 06:54 PM
millsrocks's Avatar
millsrocks
millsrocks is offline
Default Removng corrosion from grey painted casings...
Hi guys.
I have a 2009 Dyna FXDB with the grey coated engine and casings.
This winter, i forgot to spray protectant on the bike before garaging it up for the winter, and now i have a kinda egg-shell black mottling/corrosion on the primary casing.
Does anyone have any tips/tricks for removing this corrosion?
It obviously wont come off during regular washing, and hasn't shifted with proper S100 style gel-cleaners. I'm thinking that perhaps it won't come off unless i use something that is more reactive?
Any help appreciated.
All the best...
Richie.
Old 03-13-2017, 09:20 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,736 Likes on 928 Posts
Can you post a pic? Are you sure it is painted or is it raw aluminum with a clear coat?
I want to know exactly what the finish is before recommending something, but polishing compound come to mind....but again, not 100% sure what the surface is. YD
Old 03-28-2017, 11:43 AM
SJ_FXD's Avatar
SJ_FXD
SJ_FXD is offline
Had this problem with my gray motor. The finish was neglected from the last owner like it was never cleaned. I used it all, Simple green, s100, scotch brite and wd-40 nothing worked.
I ended up removing the motor to PC the frame and just painted it with VHT wrinkle paint. its been like this for a year plus now and the finish still looks great. If you resort to painting it just make sure you prep good. Remove all dirt, grime, oil and grease.
StreetBobCrowder
Powdercoat & Paint
03-28-2017 01:12 PM
Peedib89
Powdercoat & Paint
07-16-2014 11:53 AM
PoCoBob
10-13-2012 01:24 PM
vetset
Powdercoat & Paint
06-23-2012 10:18 AM
Jeff W
03-26-2012 07:25 AM
Quick Reply: Removng corrosion from grey painted casings...
