Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
how much material painting my bagger
Old 05-02-2011, 09:11 PM
DrewCfromSC's Avatar
DrewCfromSC
DrewCfromSC is offline
Default how much material painting my bagger
Hello, thinking of repainting my bagger this next winter. It will be full fairing, stretched bags, tanks, fenders. Have only painted cars and it usually takes about 3-5 quarts. Using a gravity feed HVLP Sata gun = to sparying from a spray can pressure.
Thinking maybe 1 or2 quarts of paint and reducers hardeners to match sound about correct?
Thanks!
Drew C.
Old 05-03-2011, 04:08 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
1 -2 qt is plenty.... 1 will cut it close with a HLVP gun as they tend to over spray a bit... 1qt and a pnt should be good 2 qt to be safe
Old 05-03-2011, 05:42 PM
DrewCfromSC
Thanks for the info!
Drew C.
Old 05-11-2011, 10:26 AM
badco_67's Avatar
badco_67
badco_67 is offline
Also depends on the type of paint you use and it's required mix ratio, some paints will have a 2 to 1 base to reducer ratio, some will have 1 to 1 ratio. You might pay more for a higher quality paint that has a lower mix ratio and end up needing half as much....
Old 05-11-2011, 02:24 PM
Nickrc3's Avatar
Nickrc3
Nickrc3 is offline
Also, a coat of silver or white prior to spraying the final base will reduce the number of coats necessary to achieve the true color.
Old 05-11-2011, 05:12 PM
DrewCfromSC
Good stuff going to the paint stre for some local help! Just dont want to buy way to much when is costly.
Old 05-11-2011, 05:14 PM
DrewCfromSC
Good stuff! Looking at House of Kolors stuff. Getting help with supplies ths saturday at the paint store! Thanks!
Old 05-11-2011, 07:10 PM
Nickrc3's Avatar
Nickrc3
Nickrc3 is offline
DrewC: If you're considering HOK products, I'd definitely check into Internet/Mail Order sources.
I priced all mine locally and some products were 50% + higher, with tax to boot. I try to always support the local businesses, but when the opportunity arises to save hundreds of dollars, the decision is easy.
Check into TCP Global. Total shipping (from CA. to FL.) was only $30.00 for 7 quarts of paint (clears, sealer, primer and assorted basecoat colors), plus one gallon of reducer. They have very attractive shipping rates for orders over $150.00
lookslikeahog
Powdercoat & Paint
06-22-2019 05:19 PM
LouM41
Powdercoat & Paint
12-06-2015 07:04 PM
06SGWA
09-12-2013 10:55 AM
kaptekarev
Powdercoat & Paint
07-25-2011 09:48 AM
SPARKY01
11-25-2010 02:18 PM
Quick Reply: how much material painting my bagger
