Frame paint damage
Frame paint damage
The Ultra goes in for a service soon and I just want to ask you guys for your opinion/advise on the following: The underside of the frame has, due to stone chips I suppose" a few edges where the paint has peeled off. Surface rust has appeared so it's not just "overpainting" anymore. Do you guys think that a good dealer will be able to blast this localised and paint properly or will it become a reoccuring issue. I was hoping to have the dealer correct this after which I could coat it with a coating such as truck bed liner or something similar which will cuchion the paintwork somewhat.
personally I wouldnt want a blaster of any kind close to a complete motor cycle.the blasting media gets everyplace even when it is wrapped in plastic.What I would do would be myself and I would just scuff it with sandpaper prime it and then pain it stopping at a place on the frame where I didnt have to try and blend the paint.If it isnt visible then you could stop at a masking line where you stopped scuffing it.A good spray bomb over a good primer wouldnt cost you even what half a hr at a dealer would cost
I wouldnt myself---------------if you dont get the rust stopped it will continue to work under the bed liner.I thought I was going to be smart and rhino tuffed a 80000$ stainless reefer trailer that was new.It didnt seal off and is now rusting under the bed liner and its about impossible to get offother than with a sandblaster
My question to you though is "how does a stainless trailer get to rust" (unless it's a very low grade stainless)?
Use a acidic cleaner to remove the final traces of rust before applying any primer or finish.
I grew up repairing rust in an Ohio body shop and I can tell you that removing every last trace of the rust is the most important step in the repair process.
And like someone else already mentioned, a sandblaster or the like has no place around a fully assembled motorcycle.
damn sorry-----------------for what ever reason I must of left off the part about it covered the mild steel landing gear and long members what stainless attachment stuff also rusted though.The grades of stainless on this stuff isnt a non rust medical grade
I use stainless for pump stations and there will be acid used in the room they stand as well as the acid we pump on these units. I always tell my customers that it is called stainless steel because it "staines less" than other metals. They did not call it "stainfree" , and for a good reason.
