Rattle-can paint jobs... let's see 'em!
#101
Here are some pictures of the paint I've been doing. Don't mind the mess, it turns into a war zone when I'm out there until 3am. It's nice and tidy now
It's a 2002 FXSTI. It used to have the silver engine/transmission and black paint on the tanks/fenders. I painted the engine/transmission gloss black and I crafted a navy blue metallic color for the metals
For the engine/trans I used VHT primer (3 coats), gloss black (3 coats), and two very thin coats of their clear coat. I had to use a quick mist because their clear coat really likes to "ghost" the black. After wetsanding and using some compound it turned out well. I've been wanting to have this done for 3 years, glad I finally did it
For the fenders and oil/gas tank I used a variety of products. I used Rustoleum automotive primer (2-3 coats), Krylon Fusion Navy Blue (1 light coat, 2 medium), a very light/quick shot of Krylon Glitter Blast Silver Flash (one of these small cans would probably do two or three bikes), and Rustoleum Crystal Clear Enamel. I have not painted the gas tank yet but I bought a can of 2K to use instead of the Rustoleum clear
I used the Rustoleum primer for its rust-resistant qualities and because I like how it sprays. I also coated all of the "hidden" spots (like under the fenders/in the wheel well) of each piece with two coats of it
Keep in mind I have four very bright shop lights directly above the bike, so it looks much lighter than it really is. In "normal" lighting it's much darker. The last picture is much closer than the others
This is how it looked the day I bought it
This all started with a drive belt change...which kept leading to another thing, and another, and another
Mocked up with new cylinders (sending these off soon to bore out to 98")
Primary done (90% all new stuff inside there)
Fenders
Oil tank/transmission
Profile shots (the wheel in the background was Plasti Dipped)
Fenders
#103
http://www.badasspads.com
#104
#105
#106
u def need to watch the flash times on the 2k, if not long enough u will get "solvent" gasses trying to escape under the next coat of clear.
other than that any good instruction from any autobody/paint dedicated forum will have something to go off of.
OH and be careful with the iso' paints good organic reperator, with a fresh filter, because old filters no workie, u can tell when u have been exposed, stomach ache, headache, and shitty feeling in general. Be safe, these will kill u with liver and kidney failure.
#108
I have a 2007 Street Glide, vivid black. I have been looking into powdercoating everything except a few chrome accent items. A friend told me to look into rattle-canning it and seeing how it works. I found this thread and am pretty impressed with some of the jobs done by y'all but now I really have to know... If you did front lower fork legs, horn cover, crash guard, derby, timing, primary cover, etc.... How long did the rattle job last before you had to redo it or just powdercoat it?
#109
First, I'll start off by saying this isn't a rattle can paint job. It is, however, DIY and cheap! I saw an earlier reference in this thread to using John Deere Blitz Black equipment paint. That is what this is but purchased by the quart with a hardener added. I also used their primer/sealer. Cheap HVLP gun, shot outside.
jackalsilva (06-01-2016)
