As it says it is PPG DBC, aka Deltron 2000, also note, That from PPG this is a tricoat paint and that means it will have a base color coat then will need another Midcoat color to achieve desired final color. then finally a clear coat.
Amber Whiskey Paint Code 934718 works in PPG Envirobase (waterbase). It is mixes as a 2 stage rather than in 3 stage in DBC. A pint of 3 Stage will run around $400 whereas a pint of 2 Stage Envirobase will run around $130. If you have a PPG mixing system you MUST choose "Motorcycle" under SOURCE TYPE and then choose "Harley Davidson" under MANUFACTURER. Otherwise the paint code will not come up because you will be in the default Auto lookup screen. Hope the Helps...
