Screamin Clutch.
Screamin Clutch.
I have a 2013 Sportster 72. Right away it had Clutch problems, and was repaired with a new clutch hub bearing, and an upgraded Screamin Eagle kevlar clutch kit. Now I have a screech when starting from dead stop in 1st gear. It is adjusted properly, and have tried different oils to no avail. The thing is, after warm up (about a half an hour) The screech disappears. It seems also that I get a little chirp after getting of the highway at first stop. It sounds like it may be allowing dry spots to form. Im wondering if this will effect the life of the clutch, or should I just live with it.
Brian Hintze
02-20-2018 09:34 AM
ColdRain
05-08-2017 05:48 AM
