Tranny, primary or what?
Hi all, despite the fact that I went around all threads on the forums, I didnt found solutions to my problem . HD Softail 1999 sometimes after heating at 60 mph speed starts to twitch, I hear weird sounds from the primary and bike is slowing down. The chain is ok, all fluids are new, sparks too, no filings in oil, I also changed vacuum membrane in carb. I am going again to inspect compensator but on last inspection it looks like new. Gas consumption is 12 litres on 100 miles / 31.5 mile per 1 gallon. Thank you for your help.
Miki from Slovakia
Miki from Slovakia
Hello,
Problem is that I dont know where to start to investigate my problem. Something in engine, transmission or primary area make a gritted noise, bike slow down significantly. As I wrote there are no any metal fillings in oils. I changed yesterday transmission fluid, SE sparks to stock, put little bit more oil to primary - totally is now approx 1 liter and will ride to test.
Thank you Mark.
Thank you Mark.
I drove yesterday about 200 miles. On the way back home on highway it happened 6 times on 5 th gear constant speed 65 mph during 20 miles Today I am going to change primary chain. Motor is running well. More info next week monday.
Thank you.
Thank you.
