24t compensator sprocket
Looking into replacing my 25t compensator sprocket for a 24t. I found this part at J&P for around $40 which is a lot less than what harley is asking. Will this be a direct replacement?
http://www.jpcycles.com/product/603-130
Looking to go to 3.37 gearing with the 24t compensator sprocket. From what info I have found it sounds like hd part 40269-85A was used on 99-01 Fi touring models with the MM system and will fit my bike. The JP description of the part above is a stock replacement for the 40269-85A. That leads me to believe it will work.
I was hoping to hear from someone who had experience with the JP part above. Fitment being most important but also quality of the part.
40269-85a is the correct number plus you have to change the clutch basket to get the 3:37 ratio. I'm getting ready to change my compensator sprocket to the 24 tooth also but not the clutch basket. This yields like a 3:26 ratio. I have the Baker Fat Shoe DD6-178 to take up the slack.
However what I am saying is that the JP website indicates that 603-130 is the replacement of 40269-85A for $40
byidesign
01-31-2009 12:26 PM
