To eliminate or not eliminate... compensator...
Hello.
After about 40K miles, I begin to have the usual problems associated with wear on some parts.
According to the mechanics of the local dealer, I have a problem with the compensator... this is probably true... strange noises from the primary and pulled on low speed.
View of mechanics is that it is better to replace with SE Compensator, but I'm not convinced. Price is too high and the reviews that I read were not very positive.
The question is, is it a good idea to eliminate fully the compensator?
These are the options:
http://vulcanworks.net/store_4/produ...5&cat=0&page=1
http://www.beltdrives.com/chcomp.html
Thank you in advance for your advice.
If you go Harley, the SE Compensator is your only choice.
It takes some of the torque from the engines.
Worked ok in the earlier engines but 96 and up engines may have a noise problem and it can eventually take out the starter.
My '07 has been replaced once with the SE model. Now there is a new and "improved" SE compensator.
I have the new SE Comp and it is improved over the previous model w/ needle bearings, angles fins on the comp to direct the flow of oil inside and they also provide a plastic tray that gets glued to the outer primary to more direct the oil.
Oiling was the main issue with the older model....the SE Comp needs synthetic primary fluid, which is fine and dandy with the stock clutch, but problem with anything else cause all others call for ATF (trans fluid) that f&$ks up the comp.
Some clutchs have had great results with using Harley's formula + and B&M trick shift synthetic along with the SE Comp.
LONG story short we all have one choice as of now to use the SE Comp. The others you have mentioned are crap and will only cause you a headach down the line, promise you that!
If the gear is worn pretty good (sharp teeth) there is a good chance at 40k the primary drive itself might need replacing. Imho consider a belt drive set up. Less maintenance and less power loss to the rear wheel. I did it and it really does make a performance difference.
Hello.
the bdl springless comp sprocket is NOT the answer. it caused a severe vib in my 07 fb. nice concept on function, but it locks in on accel and won't release/compensate on a cruise unless you do a sharp deceleration and that is hit or miss if it works. I took mine out and now its in the scrap bin.
don't waste your money on aftermarket fixes at this time. the only fix right now is the now current upgrade SE comp package with oil tray to prevent premature hub wear.
with the amount of issues with comps in 07 up 6spd bikes i'm surprised there's not a class action lawsuit to make hd fix their screw up on their dime.
MikieT (09-26-2021)
