Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
chain tensioner
Old 11-12-2014, 09:41 PM
sbeamer's Avatar
sbeamer
sbeamer is offline
Default chain tensioner
Has anyone converted to a different primary chain tensioner yet? What brand do you prefer? Spring or hydrolic?
Old 11-13-2014, 08:43 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I like this one:
http://bakerdrivetrain.com/attitude-chain-adjuster
2500+ installed in bikes all over the world, running strong and more going out the door everyday.
Old 11-13-2014, 05:28 PM
dawg's Avatar
dawg
dawg is offline
Received 2,938 Likes on 1,701 Posts
I run the Hayden and have no issues
Old 11-13-2014, 09:22 PM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
I had the stock setup in my 2012 103 UC and changed it out with the Hayden. The stock adjuster kept slipping down and causing a lot of slapping before it would go tight again.
The Hayden just seemed a bit too noisy for me even after a few thousand miles (and a couple re-checks)...almost like the chain was slapping even though the adjuster was installed within Hayden parameters.
So now I have the Baker Attitude that I've run all summer. No perceived noise (slapping) and the N to 1st gear shift as well as all other shifts are positive and solid.
FWIW, I have no connection with HD, Hayden, or Baker...just stating my experience with all three on the same bike. Your results may vary.
Old 11-14-2014, 07:17 AM
sbeamer's Avatar
sbeamer
sbeamer is offline
Thanks. I like to here from people who have tried different components for the same application. Too many people chime in just to raise their post count.
Old 11-15-2014, 04:53 PM
rickb's Avatar
rickb
rickb is offline
I use the stock one, but welded it. If I need to tighten it. I just grind the weld and reweld simple fix and cheap.
Yukon42
2014+ Touring Models
04-27-2019 06:58 PM
ElectraJim
12-01-2016 06:58 PM
PhatAnthony
Vendor For Sale Classifieds
27
03-14-2013 06:13 PM
JustDave71
11
06-12-2010 11:08 AM
PowerJunkie
11-05-2007 07:06 AM
Quick Reply: chain tensioner
