Quality Clutch Hub Bearing
The only bearing of that type that is a special on a Harley is the ABS wheel bearing, on ABS bikes. If you have access to yours and can read the numbers on it, or better still remove it, any bearing supplier should be able to supply a replacement. Alternatively buy from one of the sources you mention, but I personally would only do so if they mention the brand of the bearing they supply. IMHO there is no such thing as 'stronger' or 'better', all you can do is buy a well-known brand. You could ask Barnett for a recommendation?!
Tough one! Japanese bearings are fine, as are their bikes - the darned things last long enough! All ***** sounds a bit cheap to be honest. These are high speed bearings, so are a cut above the normal variety. Of those two choices I would go factory, unless you fancy waiting until you can identify the one already in your bike and calling on local bearing suppliers.
Yah I'm trying to avoid the Chinese bearings and I'm thinking that All ***** might be Chinese, but damn the markup from Harley is nuts.
Nothing wrong with mine, but was going to change it while I'm in there, but looks like it will be staying in unless I see something bad when I press it out.
The OEM clutch hub bearing is not known for premature failure.
