lost woodruff key
12-18-2014, 11:42 PM
lost woodruff key
i cannot find the woodruff key for the transmission shaft on my 84 fxr which has a 98 evo engine by the way. where can i buy one or will i have to have it machined ?
12-19-2014, 05:44 AM
Check out Ronnie's for your part
12-19-2014, 11:32 AM
You can buy key stock at any good auto parts store. Just measure the size of the keyway and buy that size stock and cut a key to fit.
12-19-2014, 11:34 AM
Are you sure it didn`t drop into the transmission?
Quote:
Originally Posted by
penmaker
... and many hardware stores also ...
12-20-2014, 06:54 AM
hvacgaspiping
From inside the primary cover?
12-20-2014, 10:18 AM
Start with a 605 flat bottom woodruff key (3/16 x 5/8) then file the height to fit the key way in the hub.
12-20-2014, 10:36 AM
Up to early `84 the Moco used the standard woodruff key, if you ask the parts guy at the dealership for this, you will just get a funny look...
Bama91
EVO
03-17-2012 04:39 PM
cadillac6661
Ironhead
14
05-03-2010 12:12 PM
section8joe
08-21-2009 09:44 PM
sinenarockandroll
03-08-2009 02:18 PM
gels55
12-11-2007 10:45 PM
