1991 FLHTC clutch cable
I haven't measured the free play on my 1990 bike, but if it is 2.75" I cannot see any easy way of adjusting out that extra 1/2" except via the mid-cable adjuster, if it will allow that. On our older bikes the adjustment of the clutch can be quite critical (I've owned mine since new) and getting it right is fun enough, without trying what you describe!
Why are you using the 'new' cable?
Thanks for the reply.
I installed it last night. Like you said ,I had to bring the mid adjuster out almost all the way . I readjusted the clutch behind the derby cover 1/2 turn out, maybe a bit less. Took it for a quick ride around the block . Its perfect. Cant go very far its winter up here in Canada.
Comfortably Numb
05-03-2021 12:45 AM
jgcable
10-22-2007 01:19 PM
