Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Let's take this even further. What's the donut dimensions
Well, if the tool is homemade, the donut OD must be made to fit the ID of the socket extension. The donut "hole" must be drilled to fit snug over the main shaft. The donut that is supplied with the aftermarket are 1.85" in OD and the donut hole is threaded to so that it can be threaded onto the main shaft and cannot move as it fits very snug inside the extended socket bore.
