Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
is this correct? there is a groove for one outer and one inner...but when I took it apart, there was only 1 retaining ring in the outer groove, but NO inner ring. Thanks guys!
If it is a sealed bearing there is no room for a ring on the clutch side...no big deal the clutch holds it on...stock bearing should have a ring on both sides.
