Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Gearing question
Old 02-24-2015, 12:55 PM
Clwells's Avatar
Clwells
Clwells is offline
4th Gear
Default Gearing question
I have a 2006 street glide with stock gear 25/36. I'm looking for acceleration. Been told I can drop one tooth on compensater sprocket and add one tooth on clutch basket then I'd have 24/37 gears.
Problem is this option is expensive. The clutch basket is like $330. Comp sprocket is $45. Then 2 hours labor since I don't have all tools to complete job.
My question is: can I just drop 2 teeth on compensator sprocket (to a 23 tooth) to get similar gearing? Would I need a bigger clutch shoe or a smaller chain?
Anyone with some expertise on this subject please chime in!!
Old 02-24-2015, 02:57 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
You can use a 23 tooth but the only way we have found to get the proper chain tension is to use the pre-2000 chain adjuster and flip it upside down. It's hokey at best.
Old 02-24-2015, 04:23 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
I've got the 24 tooth comp sprocket and the Baker fat shoe. It will gear it about half without the clutch basket. 3:26 vs 3:31 from the stock 3:15. I haven't installed it yet.
Old 02-24-2015, 04:36 PM
Clwells's Avatar
Clwells
Clwells is offline
4th Gear
Thanks for quick replies!
24 tooth and fat shoe might be enough for this season. Then if I want more can always save up for clutch basket.
Is compensater and fat shoe an easy install?
Old 02-25-2015, 06:21 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,796 Likes on 3,307 Posts
One tooth would get you to 3.28:1, 2 teeth will put it at 3.42:1 and with a 16 rear tire and a five speed I would keep it at the 24 tooth compensator and add the 37 basket when affordable putting you at 3.37:1 overall. anything over that might be too much for the road. the 3.37 should put you at about 2700 rpm in 5th at 60 mph and 3300@75mph . You'll like the 3.37:1 have fun man..
Old 03-02-2015, 07:25 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
It isn't worth changing the clutch IMHO, that is an expense too far! I used a 21T compensator on my TC88 with complete success, although that change may be a bit extreme for your purposes. I doubt if you will notice only one tooth change, whereas even a 23T gives just 25/23 = 109% torque at the rear wheel, in other words a 9% increase. By contrast my 21T gave me a 19% increase in torque, which is very noticeable.......
maddyv
07-18-2011 12:05 PM
FLSTF
12-04-2010 11:30 AM
tgaetto
07-25-2010 05:24 AM
bdn56
05-30-2009 08:35 PM
pitbull1
Ironhead
09-11-2007 12:59 PM
Quick Reply: Gearing question
