1974 ironhead shifting problems
03-24-2015, 06:10 PM
I have a 1974 ironhead that is having problems shifting from 1st to 2nd without getting stuck in neutral and sometimes gets stuck between 3rd and 4th. I tried adjusting the clutch a few times and then found that the cable was a little frayed so I changed that. Still not sifting right. Is my transmission shot or is there synchronizers that can be repaired/changed. If I do need to change my transmission, can I switch out my 4 speed for a 5 speed?
Thanks in advance for any help I can get.
03-24-2015, 06:31 PM
03-25-2015, 08:00 AM
It may be a drum alignment issue, do you have a service manual?
03-25-2015, 09:11 AM
/either the top hats are gone or the forks are bent. do you have the manual?
03-25-2015, 02:20 PM
I too have 79' Ironhead with a 4 speed and the bike pops out of 1st. Was told by PO that it was a bent shift fork. Any info on correcting the issue or as OP asked, can a 5 speed be swapped into the case???? TIA!!!!
03-25-2015, 03:17 PM
that's what they are known for bad trans. Years back when I helped in my friends shop we did at least one a week, he used to say sportster trans, helped pay all of his bills. most of the time its the forks
03-25-2015, 03:25 PM
We don't have a 5 speed for them, don't know of any one who does.
03-25-2015, 11:28 PM
I do have a manual. Thanks for the new direction, I'll check that out.
snadekow
02-09-2019 02:31 PM
chopperchopster
03-29-2013 09:49 AM
proford1
EVO
12-16-2012 03:31 PM
nwpwr22
Ironhead
04-15-2012 02:23 PM
Inked624
05-22-2009 11:27 PM
