Sealant on Primary Gasket?
I'm getting ready to replace the compensator and rotor on my 09 RK with the new SE style. All the parts have arrived but I noticed that I couldn't find anything that indicated whether I needed to use a gasket sealant when I install the new gasket on the primary cover. Do you use it or not? Thanks.
That's good to know. If the original one is still in great condition when I remove it, I'll save the new one too.
Unless it has been butchered up by overzealous cleaning or serious over tightening, don't use any gasket sealer.
Do pay close attention to the correct torque specs though and don't fall prey to the common mistake of thinking that "tighter is better" because that's the most common reason that gaskets leak.
Sure
