Torque Setting for Primary Cover Bolts
Received 47,790 Likes
The following 2 users liked this post by qtrracer:
Ben221 (04-13-2020),
Dan89FLSTC (06-16-2023)
Ben221 (04-13-2020)
Those bolts strip easily. I know at least 10 guys that have had to Time Sert the longer bolts. 60-80 in.lb. should be enough to seal the seam and not enough to strip; I wouldn't even use a torque wrench; T-handle tight like gtrracer suggests. If you torque to spec, eventually, you will strip them.
