Removing trap door locknuts
I have a stripped hole in my trap door/exhaust bracket mounting. I bought the George's garage tool to remove the trap door without removing primary.
My question is, how can I remove the trap door locknuts without pulling the primary cover or trans top cover? The trans just spins right now. Is there a way to lock it up so I can break the mainshaft/countershaft lock nuts loose?
Try putting the transmission in gear and hold your foot on the brake.
If that doesn`t work, remove the top cover from the transmission, remove the shift drum, then move the gears back and forth on the shafts while trying to turn the shafts.
You will get the transmission to be in 2 gears at the same time, this will lock the shafts so that they won`t turn.
The process of removing the trap door cross loads the ball bearings, so you should replace them (about 15-20 bucks each).
I might as well ask this here instead of starting another thread. I've got the same problem.
One of the bolts that holds the trapdoor or side door on the transmission of my '03 dyna is broken off flush with the transmission housing. The bolt hole was used to mount an aftermarket exhaust, and some ******** (not me) overtightened the bolt and broke it. Looks like a fairly common problem.
In order to get at the end of the broken bolt, it looks like I'm going to have to pull the trapdoor off the transmission.
I was wondering if it is possible to just pull the locknuts off the ends of the tranny shafts and pop the trapdoor, leaving the rest of the tranny and primary intact. That would beat the hell out of disassembling the primary and transmission.
Since the ball bearings are secured to the end of the shafts by the locknuts, maybe they are just an interference fit, and not a press fit. Maybe they would require no significant side loading to pull them or reinstall them??? Maybe get by without the expensive puller and reinstall tools I'll only use one time???
http://www.georges-garage.com/trans_pre_o7.htm
When your done with it put it on e-bay for $100 with the description "1 time use" it will sell.
You will only have to buy the mainshaft race puller then you will be able to remove the gearset. the short cut you are attempting could end up an expensive and time consuming long cut. Buy the tool from here it's $130
