all balls bearings
all ***** bearings
Any reviews on the All ***** bearings for the mainshaft OEM 8996? The price at J&P is $10.99 which scares me. Our bearing supplier in town has none in stock and usually there around 40 bux are a brand name that I've heard of. On the bearing it has Peer stamped on it and the number 6029 or 6209 depending how you hold it. Anyone used this make of bearing for a mainshaft bearing ?
The correct number is 6209 (45x48x19mm). I have done some searching for this bearing in the past, thinking I could save some money, but a bearing house will be more expensive than the dealer, and the OEM 8996 bearing for this application is a quality unit.
I would use the 8996 OEM bearing before an all ***** bearing, which very well could be made in.......
