91 tour glide with Rivera pro clutch slipping after 3200 RPM
guys I have a 91 FLT evo that Kendell Johnson owned, he did a 80hp build and a Rivera pro clutch, I just bought the bike this past week end, it is a power house but after 3200 RPMs she wants to slip bad,i have adjusted the cable both ways and when I loosend the cable almost to the end of the threads no slipping for 3 miles I stoped put her in N then back on the road I went and the slipping was back to 3200 RPMs, guys im stumped! talk to me.
Did he give you a service manual?! The correct procedure for adjusting the clutch is to back off the cable adjuster so there is plenty of slack, then remove the derby cover. Back off the central locknut, carefully screw in the central screw until it contacts, back out half a turn and tighten the locknut. Take out cable slack until you have a little slack at the handlebar (I set my 1990 bike at minimum slack), tighten adjuster in cable, refit derby cover. Anything less is not adjusting the clutch!
did all the cable adjusting still slipping, so I took off the derby cover when I got back home an was looking at the shoulder bolts, well I told my self check em an see if there bottomed out, well found 3 of the shoulder will not bottom out nore will they turn out, only one bolt is tight,and what got me to give them a check is I pulled the clutch leaver while watching the clutch pack as I worked the leaver an noticed the pressure plat was moveing only on one side,the other side would stay in place.so now I have to hack off 3 of the shoulder bolts and see what the hell is going on in there.
the fix
well guys I tor it apart an found that 3 of the shoulder bolts wasn't bottomed out, it had 2 hub bolts missing an one of the 2 that were there had backed out,who ever had it before me had the wrong fluied in the primery,I cleaned all the plates an soaked em in ATF,wiped em off an repacked em,adjusted it and the cable to Reviras spects an waalaa!!bitch runs like a scalded hound.but this morning I found the inner primery seal is leaking so now I gota pull it ALL apart so im gona do a new drive belt,new rear tire and rotor while im in there.
