Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Thick Red Tranny Fluid
Old 04-25-2015, 01:18 AM
jim70's Avatar
jim70
jim70 is offline
Default Thick Red Tranny Fluid
Picked up a '97 FXDWG recently and during my fluid changes, noticed the transmission oil was a relatively thick reddish pink fluid. Very slow to drain, and clean, but very red in color.
Anybody know what transmission fluid type this way be. I replaced it with standard HD trains fluid.
Jim
Old 04-25-2015, 02:43 AM
macride's Avatar
macride
macride is offline
Guessing here but sounds like redline shockproof heavy. Arguably one of if not the best stuff out there. Use what ya will but that is definitely top shelf stuff and it works too.
Old 04-25-2015, 03:16 AM
tfi racing's Avatar
tfi racing
tfi racing is offline
That would be my guess as well,and agree its a good product,but unless you saw it go in yourself,who knows what it may have been.
Old 04-25-2015, 08:10 AM
HDmikie's Avatar
HDmikie
HDmikie is offline
Probably Redline Shockproof. Did you notice a different odor while draining the old fluid? Redline definitely smells different than other lubes plus it's thicker than most others and drains slowly.
Old 04-25-2015, 04:53 PM
jim70's Avatar
jim70
jim70 is offline
Well, it's most probably the Redline Shockproof product, however, without knowing, I replaced it with what I know.
Thanks all.
Old 04-25-2015, 05:39 PM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
If it looks like a strawberry milkshake then it is Redline. I use it so far so good.
Old 04-25-2015, 11:18 PM
jim70's Avatar
jim70
jim70 is offline
Yes, it was almost drinkable....
Old 04-25-2015, 11:23 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,198 Likes on 11,126 Posts
If it is that thick, how does it get into all the bearing surfaces?
whit1977
10-07-2016 08:40 PM
Davemac122383
05-30-2013 09:37 PM
KCFLHRC
10-11-2012 06:22 PM
pirate4hire
10-14-2007 11:18 AM
iasporty
04-01-2007 02:02 PM
Quick Reply: Thick Red Tranny Fluid
