Primary Oil Level
Primary Oil Level
I have an '07 Ultra with a Lehman trike conversion. I was always told that the primary was filled with oil to the bottom of the derby cover hole while the bike was sitting upright and level. That requires more oil than what the owners manual says. Does anyone know what it should be? My trike is obviously upright and level all the time. Don't really want to run it low or too high and I understand the consequences of it being too low but what could get hurt by running it too full? Do I go by tried and true for the oil level or by the manual?
It's not exact as long as the clutch is sitting in the oil a little it's good. The oil should just cover the bottom of the clutches about a 1/2 inch maybe. If you over fill it can cause it to slip. Under full can cause the bike to pull at a stop.
Kayakeur
12-31-2015 12:04 PM
