Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Another Clutch Question
Old 04-30-2015, 03:51 PM
JerryDinMD's Avatar
JerryDinMD
JerryDinMD is offline
Default Another Clutch Question
Ok-have an '11 Superglide still in basement-up on a lift-decided to swap out for better cables-changed out the clutch cable-finally got the ring back in the case and back together-made an adjustment to the cable. Ok-Tried shifting-engine off-can get 1st-neutral & 2nd-wont go up any farther. Dont know if this was the case before I changed the cable-or did i mess something up in the clutch case?
thanks
Old 04-30-2015, 04:54 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
The bike has to be moving, the transmission shafts have to be turning to shift through the gears. You can get the rear wheel off the ground and spin it while shifting to double check it if you want.
Old 05-01-2015, 11:35 AM
JerryDinMD's Avatar
JerryDinMD
thanks alot
jrplane
08-08-2015 11:40 AM
JDSporty
05-30-2015 09:37 AM
ricerocket71
04-16-2012 11:50 AM
Born2cure
08-09-2010 12:32 AM
wolf1477
Ironhead
01-16-2007 04:23 AM
Quick Reply: Another Clutch Question
