Inner primary seal????
Got a question the inner primary seal the one that goes on tranny shaft..which way does the seal face??... having a discussion with the buddies..if you are looking at the inner primary off the bike you should be seeing the back side of the seal meaning the flat side goes into the inner primary?? it goes this way since the shaft from tranny slides in from the outside?? this side toward tranny??
