Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
frame
Old 05-06-2015, 10:19 PM
imbuhlman's Avatar
imbuhlman
imbuhlman is offline
Default frame
any body know if a newer twin cam motor & tranny, rubber mount will fit into a 96 evo rubber mount frame
Old 05-07-2015, 12:06 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
How new?
Old 05-07-2015, 09:56 PM
imbuhlman's Avatar
imbuhlman
ever since I took a friends twin cam with fuel injection & 6 speed.I have been wanting to do a swap, so any year that has those changes, even if it takes a few modifications
Old 05-08-2015, 09:15 AM
It's more then a few mods that transmission case bolts to the swing arm and the distance from the motor mounts to the swing arm is different from EVO to late TC.
Old 05-08-2015, 02:37 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
The short answer is no! If you have great customising skills you may be able to make it work, but it ain't no bolt-in. Of course you can also install an aftermarket 6-speed in an Evo or early twincam - I'm sure Mark can help ya there!
Old 05-09-2015, 08:51 PM
imbuhlman's Avatar
imbuhlman
I figured the front mount would need some mod's,& add a mount for the top stabilizer, I was worried about clearance on the main frame above the head's. I realize I would need all the electric's as well. I considered a 6 speed tranny kit, but I really like the twin cam & fuel injection
BlkHillsBagger
Milwaukee Eight (M8)
08-18-2017 01:35 AM
MrRocket
08-05-2012 10:16 PM
justastreetglide
06-05-2012 12:52 PM
Ruprecht
06-14-2011 07:27 PM
sandmancustoms
05-28-2008 08:05 PM
Quick Reply: frame
