Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
lost all gears
Old 05-27-2015, 10:55 AM
Dirtbike's Avatar
Dirtbike
Dirtbike is offline
Stage IV
Exclamation lost all gears
So, I was returning from a road trip on Monday. 2006 Ultra Classic. As I was getting off the highway I could not down shift. Shifter was loose, hanging downward. Rode as far as I could keeping her going. When I came to a stop, I was able to place into neutral using my hand, at least neutral light came on. Engaged clutch, placed in 1st gear, felt and sounded like going into gear. Released clutch and nothing, would not move. With bike off and what felt like first gear I can move bike freely. Any suggestions/advice?
Old 05-27-2015, 12:49 PM
djl's Avatar
djl
djl is online now
Received 2,029 Likes on 1,498 Posts
I suspect that the trans is fine but something in the shifting mechanism has gone awry. You may have to pull the trans top cover to find the problem; get out your service manual.
Old 05-28-2015, 08:33 AM
billjoat's Avatar
billjoat
billjoat is offline
2013 EGC Mine did the same thing this morning. Fix it??
Old 05-28-2015, 08:41 AM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,493 Likes on 1,073 Posts
You lost the shifter paw spring....It's fairly common.
You'll need to get the piece of the old spring out of their before you ride it again, because if the gears pick it up, you'll really have problems.
It's a cheap fix if you do it yourself.
Old 05-28-2015, 11:37 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Check to make sure your drive pulley is not stripped out.
Old 05-29-2015, 07:07 AM
billjoat's Avatar
billjoat
billjoat is offline
This was the suggestion given to me yesterday. "Check arm at transmission.
The splines and arm/lever at transmission must be tight.
Sometimes the allen screw at the lever located on the splined shaft is loose or the lever itself has stripped splines.
The lever is softer than the shaft."
Which I bought and this was my reply,"EXACTLY!! Bought the lever on the way home, $42.00, and when I got home tested it thoroughly. After a few tough shifts, it began to flop. Off and on in 20 minutes....good or better than new. THANKS!!"
Dirtbike
General Topics/Tech Tips
05-27-2015 10:40 PM
Dirtbike
05-26-2015 03:39 PM
ShrinerRider
07-18-2012 12:08 PM
1993mooglide
06-08-2009 07:56 AM
Rick5150
04-24-2009 06:54 AM
Quick Reply: lost all gears
