Fluid change
Did he give you the owners manual, or a service manual? I doubt if those oils are the recommended ones. In over 40 years of Harley ownership I have always used suitable oils that meet the recommended specs. I currently use Mobil 1 20/50 in my S&S engine, H-D primary oil and Redline in the trans.
If your bike is recent you may be able to download a free owners manual from the H-D website. Go to the Owners tab. Otherwise get yourself a factory service manual, which will answer many questions and help service your bike.
Frankly there are so many different types of 'advice' available for our Harleys, many of which are best ignored, that I strongly recommend you use the H-D book as your starting point. Otherwise you may find you never make your mind up!
Owners manuals
https://www.harley-davidson.com/cont...rs-manual.html
Also see if you can ask the guy if the what he used was the Mobil 1 VTWIN 20W50. Which others have said they run in all three holes. Probably better than running SYN3.
