Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Replaced shift shaft, now have primary/power issues
Old 06-05-2015, 02:17 PM
Dyna_Bagger85's Avatar
Dyna_Bagger85
Dyna_Bagger85 is offline
Default Replaced shift shaft, now have primary/power issues
The other day my shifter shaft stripped out on my Street Bob so needless to say it had to be replaced. Crap part is that as we all know, it goes through the middle of the primary on midglides. So me and my neighbor tore the primary off and got it replaced. Went to test ride it last night and got to the end of the street and ran into problems. She kept dying and then finally gave out. Turning the key back on and switching it to run the fuel pumped primed up, hit start and I lost all power to the bike!
I know I need to adjust my clutch cable as there is about 1/3 play before it engages the clutch, ok simple...pull the rubber boot down on the cable and adjust it. But for the life of me I can't figure out why power will cut out when I hit the start button. I lost power for a good 5 minutes, I shook the bike a little one time and power came right back. But same thing happened when I tried to start the bike again. I'm lost!!
When we took everything apart I stacked it on the work bench piece by piece as it came out so all we had to do was grab the top piece and put it back in as it came out. I had the ol' trusty service manual at myside the entire way. Torqued everything to specs. Put oil in and we to go test ride....NO WAMMY!!!
And yes first thing I did was check the battery cables. Anyone ever had this problem, is it a simple fix? Should I just take it to a shop as engine/primary/trans work is way over my head.
Old 06-05-2015, 03:36 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Check the ground strap on the frame.
Old 06-05-2015, 09:20 PM
Dyna_Bagger85
Mark you were spot on!!!! Main power cable to the starter, the nut was loose. Tightened it down, adjusted the clutch to specs, fresh oil. Shifts smooth and feels like there is less effort
Ryan4664
06-17-2015 06:32 PM
Dyna_Bagger85
06-06-2015 06:20 AM
Firemed80
04-16-2015 04:35 PM
sg2007
03-06-2014 09:59 PM
mudkaiser
03-25-2013 08:51 PM
Quick Reply: Replaced shift shaft, now have primary/power issues
