Diagnose compensator going bad?
I have a 2007 EG with 58k miles and want to know how to tell if the compensator is going bad. I have a noise in the primary that sounds to me like a chain rubbing so I got the shop manual out and took it apart. Sure enough the tensioner has three kind of deep groves in the shoe, so I called to HD dealer in Jackson Tn to see if they had one in stock. They had the gasket for $40 but would have to order the tensioner for $90. The parts guy asked if I had the update compensator and I do not. The parts guy suggest it might be the compensator and should bring it in to let them check it. Quoted over $800 to repair. Not in the budget right now.
I have ordered a M6-Primary Chain Tensioner Bt 07Up from M&M cycles and a primary gasket from J&P cycles. While I have everything apart and waiting on parts how can I tell if the compensator needs replacing?
Thanks
Thanks
Best way is to take a look. Look at the pic in the "Baker Compensator Ordered" Thread in this Forum area. The spoke area if the compensator is the best place to start. If it looks all roughed up and "chewed" on, then a new comp may be needed. If this has been going on, you will see a fair amount of metal on the drain plug.
Ok, got the chain tensioner installed and the chain rubbing noise is gone. Look at the pic in the "Baker Compensator Ordered" to compare with mine, but I can not see any holes to look into it. just solid metal.
Will try this for a while and see if anything else comes up. Thanks for the help guys.
JosephGarcia
03-20-2009 02:35 AM
