Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Harley makes grinding noise once motor starts
Old 06-07-2015, 10:57 PM
Luke Layne's Avatar
Luke Layne
Luke Layne is offline
Stage I
Default Harley makes grinding noise once motor starts
I have a 2007 Dyna low rider with 2000 miles I bought the bike used off a guy and when I pulled the primary off the starter gear was chewed up and the starter ring gear was missing two teeth so after it grinding when starting a few times I had a local bike shop replace the starter ring gear and starter gear ....now it seems the bike will only turn over quickly if I hit the starter when it's still pumping fuel and once the bike starts it sounds like it grinds alittle as the starter disengages ...I'm going to pull the primary off tomorrow and see what is going on but I just replaced the battery and cleaned the plugs and ran stabil through the gas the bike runs great just sounds weird when starting now ! Any body else have this problems ?! Oh yeah all grounds are good as well .
Old 06-16-2015, 04:59 PM
dawg's Avatar
dawg
dawg is offline
Received 2,945 Likes on 1,705 Posts
Was the starter clutch replaced too?
Old 06-19-2015, 02:31 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,792 Likes on 3,303 Posts
Can you post a video with sound. It would be a nice aide in diagnosing...
supermanotorious
09-29-2016 12:04 AM
bbest71
Electrical/Lighting/Alarm
10-20-2015 08:53 PM
95 Ultra
EVO
03-31-2012 06:12 PM
JustDave71
05-05-2010 12:18 AM
3boogitys
02-13-2006 08:36 PM
Quick Reply: Harley makes grinding noise once motor starts
