Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Identification
Old 06-08-2015, 09:46 AM
Dyna7's Avatar
Dyna7
Dyna7 is offline
Default Transmission Identification
Ok, so heres the problem.
Needed a new transmission case for my 02 fxdxt
numbers on the case are 33293-02
number in the book is 34747-01b, so thats what i thought i bought
numbers on the case i bought are 33293-99
I know that the 02 and 99 are the years the part was made, but i thought 99-05 cases were interchangeable....
the problem is my primary is not lining up with the transmission bolt holes, and if my measurements are correct they are not in the same place as the old case.
can anyone confirm that i either bought the wrong case or the right case and something else is wrong?
Old 06-08-2015, 11:48 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
01-06 Dynas were all the same case, the number on the housing is just a casting number not the part number.
Old 06-08-2015, 12:53 PM
Dyna7's Avatar
Dyna7
Dyna7 is offline
So since it was a 99 case it won't fit my bike correct?
Old 06-08-2015, 02:07 PM
Correct.
Old 06-08-2015, 07:19 PM
Dyna7's Avatar
Dyna7
Dyna7 is offline
Hey thanks Mark!
finally some closure!
Ended up doing a heli-coil in the old case, torqued right to spec.
Thanks for the quick responses btw
Krita1
General Topics/Tech Tips
03-07-2019 06:16 PM
Dyna7
06-08-2015 12:36 AM
Puppy
Flathead
01-11-2014 08:54 PM
goosehead
EVO
11-08-2011 03:13 PM
Flhfxd
11-17-2010 03:26 PM
Quick Reply: Transmission Identification
