Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Extra Clutch Plate
Old 06-25-2015, 12:46 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Default Extra Clutch Plate
This seems to be pretty easy but after a long Google search, I couldn't find the actual reason (or benefits) on adding an extra clutch plate.
Could someone explain the pros and cons of doing so?
Old 06-25-2015, 06:49 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
The extra friction plate will help the clutch hold better. Not a bad idea for a moderate engine build, along with a stiffer clutch spring. Downside would be cost if it is not necessary in the first place. The stiffer clutch spring that usually goes along with a +1 kit will cause a harder clutch lever pull.
Old 06-25-2015, 07:09 PM
lyork's Avatar
lyork
lyork is offline
It used to be fairly common to add and extra drive and driven plate many years ago. It resulted in less clutch slippage and heat when launching. New friction materials have sort of rendered it a very minimal gain anymore.
ironmike666
03-21-2019 06:20 PM
RLH3175
EVO
09-03-2017 11:53 AM
Mich
09-09-2014 04:14 PM
SANTA DEUCE
01-02-2013 05:50 PM
bobbed86
08-06-2012 09:23 AM
Quick Reply: Extra Clutch Plate
