Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Does anyone know how much chain slack or deflection there should be in the primary drive chain for a 2009 Street Glide? I have the manual and there is no measurement because it has an automatic adjuster. I am just trying to eliminate problems as I track down a vibration. I thought it was the compensator but I looked at it last night and I dont believe that is the problem. Thanks.
you can loosen it and then take it for a ride and it will adjust itself. the best thing to do is throw it away and install a baker attitude manual adjuster, set it, forget it !
