Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
2007 RK Classic Clutch missing Damper Spring Seat ???
Old 07-05-2015, 12:07 PM
longbeach_bear's Avatar
longbeach_bear
longbeach_bear is offline
Stage II
Default 2007 RK Classic Clutch missing Damper Spring Seat ???
Tran. main bearing went, probably due to over-tightening by auto primary chain tensioner, had to change trans. shaft bearings, inner primary case bear, etc.. Now I find the clutch hub splines are damaged.
On taking the stock clutch apart (never been apart) the last piece to come out was the Damper Spring. No Damper Spring Seat in the clutch hub.
I understand the SE Clutches don't us the Damper Spring and Seat but this is stock. There seems to be a bead cast in the hub where the Damper Spring Seat would go and it wouldn't sit flat in the hub (if one was installed) as the Service Manual cross-section shows.
Has anyone seen or heard of this???????????
Old 07-14-2015, 03:29 PM
JerryDinMD's Avatar
JerryDinMD
JerryDinMD is offline
im trying to figure out if i had one in my 2011 superglide or not-took clutch out for a shifter shaft seal-things got moved around but i dont lose parts-the book says im supposed to have a seat-i CANT find it!
WMX124
02-11-2018 11:36 AM
JerryDinMD
07-14-2015 03:25 PM
longbeach_bear
07-04-2015 08:50 PM
hell hound
02-20-2014 05:49 AM
SHAKEME
08-09-2011 11:31 AM
Quick Reply: 2007 RK Classic Clutch missing Damper Spring Seat ???
