Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Q
Old 07-12-2015, 01:42 PM
prplglide's Avatar
prplglide
prplglide is offline
Default Transmission Q
I recently (about 1.5 years ago) rebuilt my transmission and put the gears, etc. from my 96 wide glide into a 95 wide glide transmission case (don't ask )
When I shifted through the gears on the bench (w/out using the linkage), it went through all 5 gears fairly decent. I thought, 'ok, I'll button it back up and get it ready to ride.' It shifted good until I tried to go from 3rd to 4th. It would eventually go, but it took a few tries for me to get it into 4th gear.
Fast forward to last week and I was having a helluva time trying to shift between 3rd and 4th (it didn't matter if I was up or down shifting), and it didn't do it on a regular basis, either. It would shift fine for 20 or so miles and then just start to act up (I'm assuming because the shifter drum found the spot where it didn't want to shift properly.) When I came to a complete stop, however, I was able to shift all the way down to first.
I know I'll have to adjust the linkage, and/or try to do something with the shifter drum at some point.
My question is this: should I be able to shift through all 5 gears with the engine off, just sitting in the garage? I didn't think so, but I guess I just want some confirmation here.
Thanks and sorry this is rather lengthy, but I guess it's relevant.
Old 07-12-2015, 03:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,482 Likes on 4,605 Posts
You won`t be able to shift through all 5 gears unless you rock the rear tire back and forth a bit.
Have you checked the adjustment of the shifter pawl?
Old 07-12-2015, 07:45 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
yep ! try adjusting the shifter pawl. you could have some worn parts also.
Old 07-12-2015, 08:13 PM
prplglide's Avatar
prplglide
Not yet. That was on my list of things to check.
Thanks, Dan.
JfrenchFLHX09
10-17-2015 07:59 PM
INJEKTER
09-12-2015 06:33 PM
Next In Line
04-07-2015 04:51 PM
92oldskoolxlh
03-29-2012 10:21 PM
vince.rogers@walgreens.com
01-15-2012 09:37 AM
Quick Reply: Transmission Q
