Overfilled Primary - HELP PLEASE
I posted this in the Touring section but realized it should probably be posted here instead....
I know there are a number of posts on this subject and I've read most of the ones I could find. My apologies if this is redundant but still unclear on an answer.
I just did a complete outer and inner primary removal/replacement on my 05 EGC. (had to get to a stripped inner shifter lever)
Upon refilling the primary, which every other time I've ever done a fluid change usually takes about a quart which brings the level right up to the bottom of the clutch, bike straight up and NOT on jiffy stand as the manual says.
This time, I poured in the quart, not even close to being visible to the bottom of the basket. Grabbed another quart... started pouring that in, got about a quarter into that quart, still not visible. Ended up pouring, checking, pouring, checking until the entire second quart went in. Only then could I see the level at the bottom of the basket.
Does 64 ounces sound right????? I checked both the crankcase oil and the tranny oil and they were right were they were supposed to be.
Thanks in advance for any help or advise here!!!!
First off, the oil, transmission fluid and primary fluid are in separate enclosures. Think of it as having 3 glasses on the table about 2 inches a part from one another. Over filling one glass does nothing but make a mess on the table.
Did you look under the bike for a puddle of primary fluid?
So I just let it drain really good and refilled with 32oz as my 05 service manual says, 32oz for a "wet" and 45oz for a "dry" change. I treated it as a "wet" change at this point.
I made sure to measure out 32oz instead of just pouring from the quart again too.
Maybe my eyesight is going bad after all these years but I still don't see any oil when I look in through the derby cover. With the bike straight up (as the manual says) or even on the jiffy stand, I'm still not seeing anything. It could also be that I'm using a new oil RedLine instead of Amsoil and it is lighter in color so maybe harder to see down in through the derby cover?
I did open the inspection cover though and could see the chain tensioner and the chain sitting in the oil. So at least I know it's bathing in oil.
Wish me luck and thank you for your help guys!!!
Fat Bey
45
11-09-2019 02:40 PM
