Sticky/ catchy cluch lever after lubing with pb blaster
I just changed my handle bars out and thought my clutch felt stiffer. It couldve been from riding my dads softtail for a weekend and then going back to mine and noticed the difference. But anyway I removed my clutch handle and sprayed down cable with pb blaster. I then got a easier to move clutch lever but it was twitchy when letting off easy at first. So I went out and bought some cable lube and still have a problem. I can hardly take off in first without a jerk and cant turn slow working the clutch. If you squeeze the clutch when bike is off it just has like a squeeky clean jerk to it. Before I lubed it I could hear it making a dry squeak when pulled sometimes. But my bike does look cool. kinda wish i wouldve went 12" instead since my cables were long enough. I cant afford new stainless cables just yet so id like to make these last me a few more months. what can I do, clean it somehow and re lube or try a different lube or what?
Thanks
Thanks
Pull the derby cover off and loosen the clutch adjuster all the way out. Now check your cable in the free state. Not sure what cable you have but all modern OEM cables on Harleys for the last 20 years have a self lubricating nylon inner liner. I doubt the blaster hurt it but who knows. I would try flushing it with a silicon slip lube just to flush it out but if in the free no load state it is tight, I would replace it.
I've tried that and never did fix it. I think it may could be the actual lever rubbing. I'm going to try some grease on lever today and see. But them bars are hurting my wrists without any pull back, same pain as my mtn bike so I've ordered some burly apes and cable kit. I've spent so much this last couple weeks I feel sick ha ha
I got my cables installed and internally wired burlys and burly kit, man this is the best feeling clutch I've ever felt. I bet it's as light s my old shadow 600. Bars feel great so far, I'm going riding Sunday so I'll see how like them. Couple questions. I spoilt maybe a table spoon of primary. I had just replaced it 1000 miles ago. Do I need to replace what I dropped out or is their a minimum level?
Also how do you guys see out of your mirrors dropped down I get nothing but elbows. Do the make longer mirror stems to help see?
The primary is fine, it will sling it with only 1/2 a quart in there, they make long stem mirrors. I put extensions on mine. Made them from 1/2" hex cres bar..but pretty sure someone sells them.
