Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Howl coming from Primary??
Old 07-17-2015, 11:04 PM
Brent09's Avatar
Brent09
Brent09 is offline
Default Howl coming from Primary??
Started a few weeks ago, not loud just a howl until I almost stop?? Clutch works fine no problem...
Old 07-18-2015, 01:44 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Model & year?
Old 07-18-2015, 02:13 PM
Brent09's Avatar
Brent09
Brent09 is offline
09 ultra classic...I took it to a dealer this morning and they think front wheel bearing??? I then drove over to a local bike shop that does high performance harleys etc...he thinks transmission main bearing?? Both places drove it...
Old 07-18-2015, 05:29 PM
dawg's Avatar
dawg
dawg is offline
Received 2,958 Likes on 1,712 Posts
I'll throw a total different answer in the mix..........inner primary bearing going south (which may be what the local bike shop was referring to as tranny main bearing). The automatic tensioner is famous for overtightening the chain which in turn takes out the inner primary bearing. 09's did have issues with wheel bearings as well. You should be able to inspect the wheel bearings visually and look for oil seepage from the seal, etc. and put the front wheel up on a lift and spin it and feel for roughness or other issues in the spin. Anyhow, my bet is on the inner primary bearing.
Old 03-11-2016, 08:19 AM
AKFXD's Avatar
AKFXD
AKFXD is offline
Did you ever figure out what the problem was?
Old 03-11-2016, 10:15 PM
Brent09's Avatar
Brent09
Brent09 is offline
Yes I did find out what it was...first I replaced the front wheel bearings and both tires!! Rode home, same howl...took it back to dealer. They took the transmission apart, 3rd gear main bearing and 3rd gear were worn out!! A whole bunch of money later...my bike is awesome again!!!
danzio
07-21-2016 10:50 AM
phog light
02-19-2016 01:11 AM
fireaxxe
03-20-2015 10:31 AM
t059736
09-23-2009 09:22 AM
oregonrider
11-11-2006 09:08 PM
Quick Reply: Howl coming from Primary??
