High Pitched squeal from primary??
I have this noise, that I thought was a rear wheel bearing going, that sounds like this high pitched squeal. Now it won't make that noise if you've only been riding for about 10 minutes. But after 25 minutes of driving, it starts. It doesn't change when I pull in the clutch. It slows down when I do but it doesn't stop when I hit the brakes. I've replaced the rear wheel bearing. The noise is still there. The technician at the dealer said he heard a growl or noise coming from the cam and primary area.
The bike rides, shifts and brakes fine. I'm going to have them dive into the primary next but until that happens, should I not ride the bike?? Is it safe to ride?
Theo
Theo
