Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch will not disengage gears on 2003 Sportster
Old 07-29-2015, 04:56 PM
Flower's Avatar
Flower
Flower is offline
Stage III
Default Clutch will not disengage gears on 2003 Sportster
I have a 2003 Sportster 1200, put in the garage working about a week ago. Took it out yesterday and cannot get the gears to disengage when I pull the clutch. I can shift the gears but I cannot pull the clutch and roll the bike forward. I'm new to motorcycle maintenance/problem solving gig so any help would be appreciated.
Old 07-29-2015, 05:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,492 Likes on 4,610 Posts
Put the transmission into neutral if you need to push it around, also start it in neutral.
Leaving it in gear will make it difficult to push (and start), because even though the clutch lever is pulled back, there is some drag between the clutch plates and disks because the oil is cold and thick.
Old 07-29-2015, 06:01 PM
capttxrngr's Avatar
capttxrngr
capttxrngr is offline
Sounds like the clutch needs adjusting. Get the book for it and it will walk you thru the procedure. If you haven't yet you check the fluids and see if they need changing.
Old 07-29-2015, 09:20 PM
Flower's Avatar
Flower
Flower is offline
Stage III
I'm hoping to work on it tomorrow... Thank you for the suggestions
Old 08-02-2015, 08:36 AM
Flower's Avatar
Flower
Flower is offline
Stage III
I changed the primary oil; it was low. Worked clutch some and works perfectly. I'm new to owning and caring for a HD...looks like I need to learn a few things! Thanks for the help!
FamilyBasketCase
05-12-2018 08:14 AM
MIMM
09-26-2016 09:03 AM
tmilo1000
07-30-2012 01:30 PM
syncrocycles
01-04-2011 06:12 AM
dwg1956
11-11-2009 08:49 AM
Quick Reply: Clutch will not disengage gears on 2003 Sportster
